loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Aug 12, 2009 10:43 am
You may need a new fuel filter. It's located on the firewall, besides the brake booster. Before you pull it out, make sure that the fuel line is empty. To do this, with the engine runnning, pull out the Fuel Pump fuse from the dfuse box (below the dash board, to the left of the steering wheel) until the engine dies. Then crank the engine at least once to ensure line is empty. Once you have pulled it out, you can blow air into the filter. If air can go thru smoothly, then the filter is good. Otherwise, replace the filter.
Also, you may need to clean the engine ground leads. They are mounted on top of the engine, by the intake manifold close to Fuel Injector #2. If dirty, these ground leads can give you some starting problems and hesistation.
