Towncivilian wrote:What is the exact engine code?
I thought the guy said P0143.
http://www.obd-codes.com/p0134
That was for the left wiring connector that I sprayed with electronic cleaner.
According to that link I may have multiple symptoms. Only symptom I have is bad gas mileage and an SES light. I cant tell if its because I was used to getting 25+ city and 30+ highway. Engine runs perfect, no stutters, no RPM fluctuations, nice steady idle, nice acceleration, no black smoke.
Wiring looks fresh. Had a mechanic look at it and thought it was new. There is no frayed wires. All wires have a solid connection. None of them appear to be loose. No holes in the exhaust. No issues with anything else electronically or mechanically so I assume this rules out PCM failure.
