pgtrr »
https://forums.nicoclub.com/pgtrr-u10140.html
Thu Aug 12, 2004 10:15 am
1990 240SX 2.4L SOHC 140K mi (KA24E S13)
Servicing rear hubs/joints necessary? Good idea? Or if it ain't broke, dont' fix it?
I'm about to do the rear brake pads - they are worn and starting to get some 'groans' when applying pedal especially in reverse.
But I'm wondering if, given the 140k mi, it's worth getting into the hubs/joints. W/ the rear brake rotors removed I can turn the hubs and I hear sort of a 'whirring/rubbing' sound and feel a corresponding pulse or roughness at the outer hubs. Seems to come from the center, maybe gears but probably the inboard CVjoints or carrier side bearings - dunno (maybe it's normal). I can't feel anything obviously wrong or rough at the hubs themselves by hand turning - seem smooth but then it's highly subjective. Putting a stethescope to the hubs and turning by hand doesn't reveal any add'l specific noises however. Also the CVboots like look intact, no signs of leakage. I can feel no looseness or slop in the half shafts themselves. (I have no experience w/ IRS using CVjoints)
Q: What kind of mileage do folks often get out of the rear CV joints or hubs? Is either more or less likely to require service than the other? Should I let them go until an obvious symptom occurs? I've got 140K currently.
Q: Anything in particular I should look/feel/listen for in the axle and/or hub assembly area under there?
Q: For a DIYer are these generally 'serviced' (clean/re-grease) or replaced and how involved is it? (I've done clutches, brakes, front hubs, ujoints, timing chains but don't have any special tools for cvjoints and such)
On my various cars I'm used to repacking front hubs and the only rears I've done was on solid axles w/ bearings pressed on the shafts or IRS cars w/ UJOints on halfshafts. Never done any sort of hub work on a rear IRS and never had CVJoints before either. All kinda new to me as to both diagnosing and servicing.
Appreciate any discussion or insight into this topic! Thanks,
