Way, way more than 30K.crisfer wrote:When do you need to replace??
1. Power steering fluid miles /months?
2. Brake fluid miles /months?
3. Automatic Transmission fluid miles /months?
4. Differential oil miles /months?
Go with the manual. This is the one that does need to get changed.5. Engine coolant it states in the manual first change at 60K then 90K and 120K.
Under anything like normal usage don't even think about these anytime soon.ATF and Diff manual states at 30K if you do premium service upgrade but still excludes seven speed auto?
Thanks for the reply was just wanting to get mirage and time on when I should replace these fluids the dealer made me think I was curding damage to the car by not doing them so I figured someone would have the mileage/time I needed to replace these fluids.Starter wrote:Friend, you have asked essentially the same question three times in two different threads. Are you going to keep asking until you get an answer you like or do you just not believe anyone?
4. Differential oil miles /months?Go with the manual. This is the one that does need to get changed.5. Engine coolant it states in the manual first change at 60K then 90K and 120K.Under anything like normal usage don't even think about these anytime soon.ATF and Diff manual states at 30K if you do premium service upgrade but still excludes seven speed auto?
Absolute BS. Decent quality/name brand oil & filter every 7-8K and your car will live forever.IN.G37 wrote:oil and filter every 3750 miles at stated in manuall
