Holidazed wrote:Hey guys,
I took it in to my local Nissan dealership this morning for an oil change and basic inspection and the dealership came back with a big list of things that need to be done.
**2001 Pathfinder SE. 192,000 kms (119,000 miles)**
Can you guys help me figure out which things I can do easily myself (or elsewhere) and which are high priority for the truck?
(prices are in Canadian $)
- Battery failed load test ($200 to replace battery)
- Drive belts are cracked (AC belt) ($185 to replace belts)
- Transmission fluid is brown ($190 to change fluid)
- Brake fluid is very dirty ($102 to change fluid)
- Power steering fluid is very dirty ($119 to change fluid)
- AC system service is due ($105)
- Front left and right outer CV boot is cracked and torn ($238 each side = $476)
- Front right lower ball joint has play - needs alignment. ($335)
- Fuel filter is due for replacement ($110)
Now of course I cant afford all of that all at once (over $1500 plus tax), nor do I feel it is all necessary. The truck drives great with no noticeable problems at all.
Please let me know what you guys think about the recommended items above. Thank you!
Nissan recommended a bunch of bogus services when I got my recall taken care of.
If your battery is cranking the truck fine and there is no dimming of any lights when put under load, Its fine.
My drive belts are cracked too. Shouldn't be that hard to replace them on your own time. Belts aren't that expensive, its the Hourly rate stealerships charge.
I flushed my brake fluid myself. All it requires is two people, an old water bottle, a rubber hose and some Brake Fluid. Just go to each wheel, attach the rubber hose to the fitting on each brake(can't think of what they are called), loosen each one about half to a full turn, have the second person pump the brakes twice...once they pump them twice and hold the pedal to the floor tighten the nut up. Once you tighten the nut they can release the brake pedal. Do this about 3 times for each wheel and remember to keep the master cylinder reservoir FULL of fluid! You DON'T want to suck air in.
Haven't done my power steering yet but do what Towncivilian did. Remove as much fluid from the reservoir as you can with a Turkey Baster, add fresh fluid, start truck and turn the wheel all the way left to right several times, turn truck off, remove fluid again, add new and continue this until the fluid you are removing becomes clear.
A/C Service?
My dealership told me my Boots were torn aswell. They are not. Just take a look under the vehicle for yourself. You don't have to remove the front wheels for this but it would make your life easier.
To check your balljoints for play just jack one side of the truck up and wiggle the wheel from the 6 and 12 O'Clock possition.
The fuel filter for $110 has to be the biggest slap in the face of them all. I got a Fuel Filter from NAPA for $15. My bracket bolt was rusted badly so it broke off but a heavy duty Zip-Tie fixed that.
Almost all of this can be done yourself for under $150 if even that. Fluids are cheap...just make sure you use the proper stuff. Belts aren't too much. Checking ball joints and CV Boots is free.
Not all of this needs to be done ASAP. If your balljoints and CV boots are bad then those would be first. The rest is just stuff you should do on a sunday when you're free.
