SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Thu Nov 06, 2008 2:20 pm
I am wondering where you are getting your transmission changed for $200? I know the trans takes 12qts at $12-15 p/qt for Nissan J-Matic . I would say make sure they are flushing all of it, and also have you replaced the fluid at least once already. That is only if you have an automatic.
As for scheduled service I would say flush the differential, as well as the brake fluid. Make sure your air filter and belts are new, or at least in good condition. Also you may want to think about the in cabin filter, and spark plugs. I would also say to check and possibly adjust your parking brake and reset your base idle.
Are you havin any problems with your G at this time?
Many of the other guys here have their own recommendation for fluids, personally I like the stuff that came with the car when it was new. Factory fluid is the way to go,IMO.
EDIT- I am going to move this thread to the engine section to draw some more attention.
