netma1000 »
https://forums.nicoclub.com/netma1000-u276079.html
Fri Jul 28, 2017 1:07 pm
RogueOne Thank you for you help. I appreciated the reply to my post.
I thought that may be the case for the Index, but I wasn't sure that would be the case once you went to a specific pdf.
I was able to follow your suggestion and locate the item I needed. What I found was the relays and wiring harness for the Daytime Running Lights are not supplied on my truck. If one did install the missing components and wiring, one would also have to reprogram the BCM. I know what your thinking --- just go buy some LED's and wire it to a spare fuse, which is probably what I will do.
I have some BMW products that are a heck of a lot easier to work with using programming tools in the public domain like INPA, EDIABAS, ICOM, Rhiengold, and something like NCSExpert to write the coding.
By any chance are such products available for Nissan?
Richard (Netma1000)
