service in san jose
tijungli
Car: G35
hi folks
i have a G35 sedan for 15000 miles service. however, infiniti dealer wannna charge me 360 for this service. I was wondering is there any good local garage that is good to go? my car is 75000 miles already..
telcoman
tijungli wrote:hi folks
tijungli
Welcome to NICO
INMHO you are better off doing it yourself.
Buy an air filter, oil filter, cabin filter from the Infiniti Parts deptment and 5 qts of 5w-30 oil on sale.
Acquire a set of ramps, jack stands, 1/2" & 1/4 " drive socket set, plastic drain pan a couple of funnels, a 1/2 drive 21mm deep socket, torque wrench for rotating tires.This should not run over $300. I use craftsmen tools from sears that you can always find on sale. You will save yourself thousands of $$$ in the long run.I still have my first set of tools from sears in the metal tool box that I purchased over 40 years ago.
Changing the Air & cabin filters are easy and you can search on this site for specific writeups on how to do it. After I cleaned out the dirty housing for the air filterin the above photo, I discovered that you only need to remove the electrical connector for the MAF and the 10 mm bolt. Pull up the entire housing, Unsnap the 4 clips holding the air filter box closed, pull out the old air filter & insert the new one. Shouldn't take more than 10 min the first time & 5 min thereafter. Don't forget to reinsert the electrical connector prior to starting you vehicle or you will get a check engine light.
Telcoman
Modified by telcoman at 1:26 PM 7/22/2008
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I agree about doing MOST of it yourself.
If you feel comfortable working on cars, do it all. If you are only a semi-DIYer. Do the air filters, oil, and tires.
Leave the spark plugs to the pros.
You could do the transmission, differential, and radiator fluid too on your own.
