Just regular maintenance for now (and knock on wood). 06 G35x with 26K miles. But I'd like to strike up a relationship by going to the same dealership for routine maintenance, in case I need any work done later.Haitian_King wrote:What are you looking to have done?
Yeah but unfortunately they are a bit too farmarlin29311 wrote:Flemington Infiniti is really good. My mom has never had any issues, and the Nissan is really good too.
Where was the car serviced originally? Have you tried the original dealership? That's what I did for my MDX. The original dealer is in PA, so I go there for service and maintenance.06x wrote:
I called SD Infiniti in Denville and made an appointment as, between the above two, it was a "Center of Excellence" for whatever that's worth.
They said I needed an oil change (39.99) and brake fluid change (109.99). (And to check if the previous owner had changed the fuel injectors.) However, now that I'm looking at the maintenance schedule, it's only recommended to *check* the brake and other fluids - there's no reason to automatically assume it needs to be changed, is there?
The car was bought in the Scranton PA area, which is way too far to go on a regular basis.Haitian_King wrote:
