gtxman6 wrote: Also for the cvt transmission, it says only use nissan cvt fluid only, is there a alternative out there? If not would nissan sell the fluid to you.
Nissan CVT fluid is the only one available and can only be purchased from the dealer. There are no substitutions here. It's very expensive fluid at $20qt and the Rogue requires 7.5 qt (FWD) or 8.5 qt (AWD).
IMHO, leave CVT service and fluid changes to the dealership. The transmission computer actually keeps track to the fluid usage/condition and tells the tech when and if the fluid needs changing. The fluid changes do not need to be done very often... unlike older automatic transmissions.
