Service Engine Soon light
pegasus
Car: 2008 M45S
I have a 2008 M45 S with 114,800 miles, the light came on this morning. Is it a regular service interval light, or potentially worse? Thanks.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
When was the last time your car was serviced? What was done at that time?
2008 Infiniti Service and Maintenance Guide
szh
Car: 2018 Tesla Model 3.
pegasus wrote:
Fri Aug 18, 2017 10:22 am
Are you talking about what we refer to as the "Check Engine Light" ... in Red? This is a generic light that comes on whenever the car reports a Diagnostic Trouble Code (DTC) for a variety of reasons.
Could be as simple as a fuel cap that is not on properly (or cap is leaking gasoline vapor ... happens - will need replacement) or something more serious.
Best to read it quickly and see what it is. You can rent an OBD-II reader for free from Autozone, for example. Or have the dealer read it (will cost some, of course).
Z
EdBwoy
Yep! Nissans don't typically have a maintenance reminder light.
In the manual it says the service engine soon is a malfunction indicator light. So SES = MIL = CEL (check engine light for us laypeople). Confusing I know, but words are better than symbols that not everyone can interpret.
Page 2-19 of the owners manual indicates it could be as simple as a loose gas cap, or something more serious that needs the code read first, as advised above.
pegasus
Car: 2008 M45S
Had the code checked, P1111 -Intake Valve Timing Control Solenoid Valve Circuit Bank 1. The valve uses oil flow to control timing, I'll try changing the oil (I have let it go a bit long this time), clear the code and see what happens.
