Service Engine Soon light
magnusbeck
Car: 2011 m56x
So this light just popped up on my 2011 M56x with about 95k miles. Dealer says it's $150 just to diagnose but that goes towards any repair. I'm a little wary of taking this kind of machine to a regular parts store for a diagnostic. Any advice?
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
The code that Autozone or Pepboys pulls will probably be the same code, so give it a shot. You should think about getting your own Bluetooth OBDII scanner. It plugs right into your OBDII port and interacts with your smartphone, android or iphone. Allows you to clear most codes. Most are relatively cheap and can be found on Amazon.
magnusbeck
Car: 2011 m56x
thanks...I will check with AutoZone before I shell out the dealer $$. I don't know how to use an OBDII scanner and I'm afraid I would do more harm than good.
reggiebrown40
magnusbeck wrote:thanks...I will check with AutoZone before I shell out the dealer $$. I don't know how to use an OBDII scanner and I'm afraid I would do more harm than good.
you can't do any damage. you can only read and clear codes.
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
take it to autozone first get the code and report back someone here may know..also google is your friend :) I've had SES light come on my 07 M35 sold, it was just a loose gas cap
Debonair
Car: 2011 Infiniti M56
lovemycarM35 wrote:...get the code and report back
This. If not by Autozone get yourself a low buck OBDII scanner. They start around $15 on Amazon. There is no way to damage the car with a basic OBDII scan tool. And it pays for itself the first time you use it.
DredM56
Car: 2011 Infiniti M56 2004 Subaru Wrx STi
This or get a bluetooth obd2 scanner and download the torque app on your phone
magnusbeck
Car: 2011 m56x
Thanks, all!! I will check back once I know more.
magnusbeck
Car: 2011 m56x
Code is P0106 Manifold Absolute Pressure/BARO sensor range/performance
It's actually listed twice if that matters. Any recommendations of how I should proceed?
DredM56
A vacuum leak or intake leak, bad wiring for the sensor, or the MAP sensor itself is bad .
