ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Wed Mar 30, 2011 1:59 pm
What grade of fuel is recommended as per the book for a 2001 Pathfinder? Using hightest fuel when 87 is recommended will create problems with ignition, mainly the HT 90-94 range will actually slow down combustion. This in turn can create a miss-fire condition. If this is the cause your coil packs, ignition cables, plugs may be all right, but.
Using a spark plug for 105,000 miles is lunacy, but it sells cars to the public that DO NOT WANT TO DO MAINTENANCE
Regular and routine maintenance is crucial, especially when ethanol crap is now at 10% and the governments of our counties are thinking of increasing it to 15%.
If as the owner of this Pathfinder you think that a spark plug change is difficult, it may be prudent for you to find a reputable honest mechanic.
Buying a used vehicle is a very difficult challenge these days. Most people do not maintain their vehicles very well, they refused to see the value in keeping their cars in good shape. Along comes an unsuspecting buyer and the seller will sell that poorly maintained vehicle to someone else.
If you are that someone else you have a choice, learn to maintain that car or pay someone to do it.
Reality is real, a well maintained vehicle will easily get 20 years of service. A not so well looked after car will get a lot less in service life. The cost of a new 4 x4 at around 35000-45000 dollars plus all the taxes can be avoided by doing maintenance. The routine is much more than what the manufacturer states: usually severe, thus more often. The simple act of timely oil changes alone will add life to a vehicle.
Like the commercial said, "We'll get you now or later" is true. Look after your vehicles, learn, be informed. The ability to work and perform regular maintenance on a car, truck or lawnmower will increase the lifespan of that machine, will reduce the money spent in buying yet another machine and will give you pride and comfort in knowing the work was done and done to the best of your ability.
