attofarad »
https://forums.nicoclub.com/attofarad-u73688.html
Mon Jan 11, 2010 4:33 pm
You might consider buying a cheap OBD2 reader, so that you can pull your own codes, reset them if you like and see whether they come back (will take a few drive cycles if they do, so don't think it is cured the 1st time you drive it after reset). In any case, you want to know that the system is trying to tell you.
My GF has an intermittent PO160 code (rear oxygen sensor, driver's side) which likes to show up once in a while. Last time I reset it, it stayed off for nearly two years; just came back on and reset again last week. I don't think the error is real, or maybe a connection is a bit corroded.
