DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Mar 19, 2003 3:15 pm
I don't know how different your car is from mine. I have an OBD I '90 Q45. Your car's an OBD II. A very common thing is for one problem to cause 2 error codes, and very often one of the error codes is the knock sensor. For example, if I have a bad injector, it'll cause the car to run very rough. The bad injector will give one error code, and the rough-running engine will create an error code for the knock sensors. If I replace the injector, it fixes the rough idle and both error codes disappear. Again, not sure if this is entirely relevant, but I would investigate the po401 error first. They should give you info a little less cryptic IMO. That's like paying them to tell you that you've got an error light on. Duh!
