"service engine soon" light...DTC MIL #93 error code?
sheadee240
got the check eng light on turned the screw on the ECM to put it in diagnostic mode II and it has only one error code a 93.
DTC MIL 93 doesn't exist in the 1995 Nissan Factory sevice manual?????????????????????????????????????????????????
My car is a 97, but I don't think there are any significant electical differences.
Any help out there????
Thanks
drjohn
I believe that is read as a 0903 code which is the vent control valve for the evap system and is found at the carbon canister.
sheadee240
drjohn wrote:I believe that is read as a 0903 code which is the vent control valve for the evap system and is found at the carbon canister.
Thanks for the reply. Another guy told me that too, but I thought he was just pullen my leg, because he wanted to sell me his carbon canister.
I don't have a scan tool. The S14 doesn't need a scan tool to read codes. You can pull the ECM (forgive me if you know all this) turn the mode set screw wait 2 secs turn it back (with ignition on)and count the 0.6sec flashes which equal 10 and count the 0.3 sec flashes which =1 and add em up.
I got 9 flashes @0.6 sec each followed by 3 flashes @0.3 sec each, which is a 93.
I'm guessing that this 0903 is if you use a scan tool, because you get a whole diffferent set of codes that way. Anyways thanks for the help and let me know if I am making any sense or not.
If I'm reading it wrong, can you tell me what I'm doing wrong?
Cuz, I thought I was doing it according to the FSM.
Anyways thanks alot for your help
Thanks again,
Shea
drjohn
You got the counts right just put a 0 in frt. if the flashes are less than 10. A code 1008 would be 10@6 and 8@3. The vent control valve could have a leaking o-ring, a broken or dirty connection, or sometimes insects make nests in the vent line and clog it.
sheadee240
Yup, I was looking at a 95 FSM to diagnose a 97 S14, I thought they were the same deal, but the diagnosis codes are different.thanks a lot!!!
I'm sure this is a stupid question, but where is the The vent control valve? The FSM says how to diagnose it, but doesn't say where it is exactly.
drjohn wrote:You got the counts right just put a 0 in frt. if the flashes are less than 10. A code 1008 would be 10@6 and 8@3. The vent control valve could have a leaking o-ring, a broken or dirty connection, or sometimes insects make nests in the vent line and clog it.
