I was driving the day before yesterday night and the service engine soon light popped up. I went to Autozone and had them use the ODBII scanner to pull up the codes. The codes P0325 P0440 P0446 showed up.
P0325: Knock SensorP0440: Evaporative Emission (EVAP) Control System (Small Leak)P0446: Evaporative Emission (EVAP) Canister Vent Control Valve
The guy at Autozone said prolly your gas cap. I chceked the gas cap and when I removed the gas cap there was no pressure. No wooumph when I removed the gas cap - almost like it was just sitting on top rather than making it airtight.
I found some other discussions about this code:
http://www.obd-codes.com/forum...=4139
and a good writeup about the Nissan evaporative system.
http://www.asashop.org/autoinc...s.htm
I guess I will start with the gas cap. Any idea on a good quality gas cap? Also, any idea on a good quality EDBII scanner to reset the light?
I wanted one to connect to USB or bluetooth to my computer but they're all only shipping from China on ebay.
Thank you.
