02pathfinder »
https://forums.nicoclub.com/02pathfinder-u245363.html
Mon Dec 15, 2014 6:52 am
2002 Nissan Pathfinder
My SES light has been on for awhile. This past weekend I went to get it inspected and it failed (obviously) do to the light being on. The states machine (Delaware) gave me a code of P1140. Looked up the code and seems like a simple fix. So I decided to do the old gas pedal trick to reset the SES light. Sure enough it blinked 1 1 4 and then the typical 10 flashes. So I shut the car off, turned it back on and the light was off (did not drive). The next morning I started the car and the light was back on. So I did the same reset trick and got the same code. However this time, I restarted the car and headed to work. Not even 200 yards down the road, the SES started randomly blinking. No pattern or consistency. So of course I research that and get all kinds of people saying to get it to a mechanic NOW as a flashing SES light is bad. Half way to work, I pulled over and did the reset trick again. All with the same results. Started to finish my drive and the light started flashing again. The entire drive (about 18 miles) the car ran perfectly normal. No hesitation, no misfires etc. So is this really a serious issue (cat converter, spark plugs, coils etc.) or is this some sort of faulty wiring? Wouldn't I get other codes if it were a more serious issue?
Rogue One on Wed Dec 17, 2014 9:21 pm, edited 1 time in total.
Reason: Moved to correct forum
