kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Mon May 10, 2010 8:14 am
The majority of the time with a newer Nissan like yours the problem is the gas cap not sealed properly, most likely after last fill it was not "clicked" enough, you need to tighten it until it clicks at least 3 times otherwise the code your dealership will discover is "fuel system air pressure" because the gas cap didn't lock and seal properly. If your vehicle does not have any noticable problems with drivability, ideling etc, I'd guess that this is your problem.
Tighten up the gas cap several "clicks", then you'll have to drive up to several days for the code to clear (i.e. the check engine light will go out after a few days, I can't explain why it takes so long for the code to clear but this is based on experience on the Rogue and Murano forum, this is a VERY common situation).
