VA99Q45 »
https://forums.nicoclub.com/va99q45-u11730.html
Fri Oct 15, 2004 2:00 am
Yuan,Definitely you want to have your car scan either through the dealer or autozone. Makesure the 02 sensors are causing your serivice engine light before you change them. The 02 sensor is ~$70 a piece. The two rear o2 sensors are ~2 hours DIY kind of job. The two front o2 are very hard to access. I think you better off getting someone else doing the two front o2. If you going to DIY, I recommend borrow an o2 socket tool set from autozone. You will definitely needed.
