cjeagle1 »
https://forums.nicoclub.com/cjeagle1-u58012.html
Wed Apr 25, 2007 12:16 am
My service engine light turned on last week. I went to Autozone to get it read by the OBDII reader and got a reading of P0430 catalyst efficiency low-bank2.Probable causes is cat converter defective due to 1.engine misfire or running condition 2. large vacuum leak 3. engine oil leakage into exhaust-valve guide seals, piston rings. The guy at Autozone cleared it and the engine light has remained off since(3 days now). Normally I would just take a wait and see attitude until the light turns on again. But after asking the dealer I recently bought my 2002 QX4 last February from, a copy of their inspection records, apparently they had the same engine light and P0430 reading which they cleared and did nothing about after the light did not turn on again.
My question is whether I should wait for my service engine light to turn on again or have my truck checked. Apparently there is a service bulletin for this code p0430 for 2001 Qx4s to update the software. Should I go to the dealer to have this done?
Modified by cjeagle1 at 3:10 AM 4/26/2007
