Amosnorider »
https://forums.nicoclub.com/amosnorider-u131343.html
Mon May 04, 2009 8:53 am
Update.After going to Advanced a couple times i finally figured out that bank 1 sensor 2 was my bad one. Its the downstream white heated four wire sensor Bosh # 13374. I only changed the bank one sensor even though it would have been a good idea to do the other bank (red cord downstream sensor). Both sensors run the same line and use the same anchor points. Took the neg battery wire off for over an hour to clear the SES light. 20 mi so far and no light.Word to the wise- when removing the old sensor- unplug at the clip then, unscrew the sensor but only to the point where you can rotate it the rest of the way by hand. starting with the plastic wire anchor closest to the top of engine work your way down toward the bottom. There are two or three points under the car by the oil drain plug where its really hard to get some needle nose in there to release the anchor. So i just got some side cutters and snipped off the back side and the anchor and it pulled right out. Finish unscrewing the sensor with the wires completely free. Installing the new sensor is a piece of cake. Put anti seize in the threads and screw sensor almost all the way in. Then just snake the wires back up thru the engine clipping the plastic anchors into place as you go. TIP!!! make sure you keep the wires straight and not twisted or touching hot exhaust components. Once your done, finish by snugging up the sensor underneath with the correct tool.Plug battery back in and hope your light does not come back on.Good luck. Hope this helps someone.
