Car is a 1999 Infiniti I30. Check engine light is on. Read the codes out and got:
-P0138 - EGR flow malfunction-P0400 - O2 sensor high voltage
Again suggestions on where to start? Does this sound like one problem that is causing both? Or two separate problems?
