Service engine light-Gas tank won't stay pressurized
Benster
Car: 2004 Nissan Pathfinder LE Platinum 4 WD
2004 Nissan Pathfinder LE-104,000 miles
Service Engine light came on a few days ago. My wife had filled it with gas, so I checked to make sure the gas cap was on and "clicked" when I turned it. Not sure if it was on all the way or not, but the light is still on. Ordered a generic gas cap on Amazon, Gates brand, and will try when it arrives. Any other suggestions?
Thanks
Benster
Sorry, forgot to add this to original post. Took it to auto parts store and had them read the codes. They said the gas tank was not holding pressure.
fleurys
Car: 2001 Pathfinder , Locked and loaded !
Check your evap lines, but the best would be to run a smoke test on it..you would see it right away...
