Folks,
I have a few questions on Serpentine Belt replacement on ideally a Rogue Sport, 2018 or thereabouts. I think a Rogue from that model year would also be a similar layout.
1. Did you do the job single handed or need a helper? Reason I ask is there is a guy on you tube who either has two left hands or has an assistant, though he doesn’t say he has either.
2. Did you remove just the small plastic access cover or the entire plastic wheel arch protector?
3. Any belt threading tips, I’m assuming the Crank is the last item to have the new belt threaded onto?
Thanks
