vm_boy »
https://forums.nicoclub.com/vm-boy-u220493.html
Sat May 25, 2013 4:25 pm
I just got done doing this repair. I just wanted to add a little word of advice that I never saw in any write-ups. I had a really tough time moving the tensioner with just a wrench. I didn't have one long enough to really move it and then hold it. I certainly didn't have a free hand to slide the belt around it. After calling a local mechanic, I learned that Autozone has tool called a "Serpentine Belt Tool". You can rent it for about $30 (fully refundable deposit!). It's essentially a really long, thin wrench that allows you to snap on/off different size heads. You'll need the 14mm for Altima 4-cyl. Once you get that head on the bolt right, it should rotate clockwise with only one hand, and then you'll be able slide the belt over the tensioner with the other.
Have fun!
