SR20Essex »
https://forums.nicoclub.com/sr20essex-u41694.html
Mon Oct 30, 2006 5:02 pm
I'm in the exact same boat bro.
Ive searched and found everything from; boost leaks, to sensors gone bad, wiring harness problems, coil pack problems, and broken rocker arm.
mine started this crap last night; I was running it pretty hard, everything was fine, then all of the sudden it starts bucking and poping at 4500rpm's or full boost (~12psi).
Ive tried coil packs (no change), and checked wiring so far, when I get home later I will try looking for a boost leak or MAF problem (dirt, cracks, leaking hoses...etc.)
