seriously in trouble...
drifter sx
Car: the usual
im postin this in the Technical section also..
ok so i went home for the weekend, left last thursday when the ocean decidied to fall from the sky.. everything was flooded, rainin so hard i couldnt see my hood. of course the worst thing that could happen happened.. i hydroplaned and spun out going 65. i wound up in the grass median, that was sort of a water trough. its designed so the water on the road falls into the median. i wasl totally alright, and my car was perfect too..but since it HAD been raining all day my tires were half buried in mud, no way i was gettin the car out. so i got a ride to the next town by some people and called my parents and a tow truck. tow truck was to far and too expensive so my dad and i decided to tw it out ourselves.. the next day. when we went back, the car was underwater !! :angry7: i had water up to my steering wheel !!!
we towed t out and 45 minutes back to my house.. i spent 2 days just drying it out. but needless to say, it doesnt start now..
of course i checked it all out BEFORE i cranked, i even changed the battery, motor and transmission oil to be safe. for one, i dont hear my fuel pump turning on, and thats an easy fix. but im not gettin spark to the engine. all my electrical works, lights blinkers wipers radio EVERYTHING.. but no spark. the engine cranks like its TRYING to start, but it just doesnt kick on.
a friend said my ECU might be fooked, so i checked it and sure enough there was a lot of moisture on it. ive NEVER messed with the ECU so i dunno how to tell if its bad or if i killed it..
anyone have ANY friggin idea how i can fix this??? or should i just bend over now? :help PLEASE HELP
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Wait for the ECU to dry :)
If you turn the car on [on but not cranking] there should be a red LED that comes on [on the ECU].. I think that indicates it's working.. check all fuses/relays/fuseable link thingies in the engine bay & the ones by the lower left driver kick panel.. You can also put the ECU into diagnostic mode and it should display any errors that it's got by blinking the check engine light.. you can also reset it & see what that [if anything] does..
Ummm... also ask Nistech in the mechanics section, for he is the supreme being.
