^ Yeah it should be, but he needs to do some research on his own first...
I'll give my two cents. First the RB26 is the Godzilla motor that best compares with the 2JZ (4th gen Supra motor). The RB25 isnt a bad compromise, as it cost a good deal less, and only gives up 100cc in displacement.
Most RB26 to 240sx swaps use the RWD RB25 transmission. If it can handle these wild RB26s running around, I sure it can the power the RB25 can realistically produce.
The RB series are pretty tough, but upgrading the internals is always good insurance. WDRacing (a moderator) made 400+whp on a stock block RB20. I'd guess the RB25 could do 500whp pretty easily on a stock block.
I have heard on the Greddy intake manifold (a common upgrade) creating lean condition in the rear cylinders, but there are a few newer 'custom' manifolds that guys hae been using. AEM EMS has done wonderful things on the KA, so I'd bet it would very impressive on the RB motors. There are a few guys on here who are using it.
Check out the RB forums And I just found this post by searching,
zerothread?id=71955
Welcome to NICO.Woohoo, another local guy too!
