Darius wrote:You know...Eikon brings up a good point. You're running a stock turbo, stock injectors and stock boost since you do not have a boost controller (that I heard of anyways). You do not need an upgraded ECU at this point, but it shouldn't make any difference when tuning. You can tune a completely stock motor for 7 psi and it should run like a champ.
With or without a stand alone ECU, this is where a boost controller comes in to play. Without it, you are NOT going to boost higher than the 7 psi of the stock wastegate spring. I was really confused when you said you were trying to run 14psi, but didn't have a boost controller and were running the stock gate and wondered why it got up to 7 psi and stopped. You are correct, that is the stock spring rate and will only allow you to run up to 7 psi. I would think your tuners would know this too.
Lucky7, cdorhout, and I have all run the motor tuned on stock injectors, stock turbo, and PFC with boost controller kit and the injectors do not max out on a reasonable tune. MAF is good to go too. I think lucky7 actually dyno'd his at 306whp on the stock setup with just a FMIC. So you are far from the tuning limits of the stock setup.
OK, I'll try to answer some questions here since everyone, and rightly so, seems confused.
I bought the car in August for $10,250. Many things are still stock, but some mods have been made. The problem is that I can't be POSITIVE that the mods the guy said he made were actually done.
Anyhow, the car wasn't running properly. When I hit the gas hard the turbo would go in pulses instead of one steady boost.
I also wanted to run more than the stock 7PSI of boost to get more HP out of the motor until I do an eventual turbo upgrade, and I was told the way to do this was thru tuning.
The tuner later told me that my system wouldn't maintain more than 7PSI of boost pressure. He told me that if I'm going to do anything else to the car I'll need engine management, so not to think it was a waste of $800
The car does have an APEXI Dual SBC boost controller, but I'm not sure if it is working correctly.
It has Walbro 255lph pump, TurboXS type H blowoff, and was bored to 2.7l and fitted with Wiseco forged pistons...
I'll be happy to answer any other questions, but that is all I can recall that is relavent.
