ZootedS13 »
https://forums.nicoclub.com/zooteds13-u142930.html
Tue Feb 09, 2010 7:22 am
yes, key is on position when i test everything. there are so many variables that change what prong is getting power on each plug.
ill try to be more specific.
when those tiny grounds that bolt to the manifold are grounded
tps-no main power, no signaleach ignition coil plug- no main power, no signalcas-main power, but no signal
when those two tiny grounds arent grounded
tps- getting signal, no main powereach coil plug- getting signal, no main powercas- getting signal and main power
but there are other variables such as if the cas is plugged in or not and some plug on my body harness in my engine bay that is looped back to itself for some reason. im pretty sure iv tryed every combination of switching up wether the grounds are grounded or not, not looping that plug in my body harness and plugging in the cas.
no matter what i try i have yet to see main power to the coils whatsoever. i cant believe this stupid wiring is the only thing holding me up from driving this beast.
