Serious transmission problem? No pun intended.
wannabevip_g50
Car: 1994 Infiniti Q45
Car: 94 Q45
Problem: On cold startup, when shifting from "park" to "drive," it takes the car 3-5 seconds to kick itself into drive gear. RPM's kind of go up right when transmission is trying to shift itself from park to drive too. Any ideas?
wannabevip_g50
Anyone?
Q451990
I would try a pan drop and filter screen replacement first... if the filter is clogged, it can cause reduced pressure and starvation. Do you hear any buzzing or howling noises?
Heath
wannabevip_g50
No buzzing. No howling noises. Just takes a little longer than normal for the transmission to kick from PARK to DRIVE.
wannabevip_g50
By the way, dumb question but...how many (total) engine/transmission mounts does the 94 Q45 have? 2 or 3?
wannabevip_g50
Anyone? :(
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
A 1990-1996 Infiniti Q45 has three mounts for the engine and transmission. Two are for the engine and one for the transmission.
wannabevip_g50
Infinitiguy19 wrote:A 1990-1996 Infiniti Q45 has three mounts for the engine and transmission. Two are for the engine and one for the transmission.
Thanks so much for the response. Do you know if there are any diagrams that show how to replace these? It doesn't seem like q45.org has anything.
Infinitiguy19
wannabevip_g50
Infinitiguy19 wrote:Their sure are: http://www.nicoclub.com/FSM/Q45/1994_Q45/
Crap. Which section would it be under? lol
Infinitiguy19
EM-Engine Mechanical and AT-Automatic Transmission.
