k6kicker wrote:Its very worth the while...the n/a z is a great deal lighter (no hicas or other annoying piggies) has better gearing (4.06 as opposed to the 3.4 on the tt)and its far cheaper to turno your n/a instead of selling and buying a tt and with the rebuild method you get new (and stronger) interals and whatnot...its like ahve a new motor
The TT has 3.69:1 final gear ratio. Also, the weight difference between the two cars comes largely in the form of the turbocharging system - 2 turbos, 2 intercooles, and about 8' of extra piping that the NA doesn't have, in addition to the HICAS system. Granted, the hydraulic HICAS can be annoying on the earlier models, but I hardly ever notice the electric setup on my 95. Also, it is a hell of a lot easier to do a rear end swap on a TT to eliminate the HICAS and get the NA diff than to do the motor swap. If you haven't worked on a Z32 before and/ or don't have a *lot* of patience, I would *highly* recommend another path.
