Serious knocking....
JaaDogg
Car: 1989 240sx
Here is the long and short of it... I had a serious knocking noise, took my car to a ****ty shop and eventually had a "used" engine put in the 89 240sx I call my daily driver. The car stopped knocking for a while but basically returned back to knocking... The lifters have been changed so many times I have lost count. Sometimes it is quiet but most of the time it knocks, especially after it has bee driven for a long distance (try not to do that anymore). Is there anything else aside from the lifters that could cause that knocking noise? Any help or advice would be greatly appreciated.
SyndromeVII
Car: 91 240sx
knock sensor maybe
s13redtaz
Car: 91' S13 Donated and gone..., 96' Toyota Avalon (DD), 92 coupe*SOLD*,92 5 speed Hatch
which motor was it "replaced" with single cam or dohc?
s13redtaz
the reason i ask is the dohc engine is known for the timing chain guides being rubbed by the chain causing a tick/knock.
wankelTII
What weight oil are you using? Does it do it all the time or does it come and go or change at all?
^^^Knock sensors dont make noise, they sense high frequency vibrations.
Florida240sx
Put some lucas in there it'll quieter her down...... If it was a rod bearing then it wouldn't go away
