ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Mon Aug 29, 2011 7:35 am
Spark plugs are the end use, the final thing to work with the ignition. A fouled plug cannot always be blamed for the fouled plug.
There are description of plugs at different stages of use, find this great picture and it will help diagnose the problem with the plug.
Cars with independent coil packs also have independent sources of problems over a plug system that uses a single coil. Because the coil pack at each plug the coils are very small in comparison to a bigger central coil and this small size makes them prone to voltage break down via, dirt, water, mixtures of dirt and water and vibration and heat.
Central coils are oil filled, larger in size but produce much more energy because they supply energy for all plugs not just one.
The production of the proper spark size and shape uses a lot of energy and these coil packs may be sized too close, that is too small for what they do, but the manufacturers of the engine can reduce costs and materials by using single coil packs as compared to the complex system that produces a spark and lat the right time for every cylinder via transistors a large coil.
These coil packs need a lot of PM compared to their bigger cousin. It would do to keep them very clean, keep oil mist off of them, atmospheric contaminants play havoc with the small surface areas and large voltage. A high voltage spark produces a track and this track produces carbon, dirt attraction and when voltage at 20,000 volts the track made can lead the voltage to other parts around the coil pack and cause it to self destruct.
These separate coils need to be very clean!
