jfck2000 »
https://forums.nicoclub.com/jfck2000-u36666.html
Fri Oct 06, 2006 8:08 am
Sorry this is a bit lengthy -I have a 1995 Infiniti Q45t that I bought from my dad who took meticulous care of it. He had every maintenance service done to it on time, changed the transmission fluid every 30,000, oil every 3,000 miles, etc. etc. When I got it, I noticed a small leak of some sort under the car midway kind of in between the two front seats. It started out to be about the size of a nickel, but as time went on it got to be as big as a softball. I also smelled a burning scent every time I drove it. I took it to a mechanic locally who said that the Valve cover gasket on the driver’s side was leaking on to the exhaust and burning, thus emitting an odor. So my brother in law and I decided to make this a weekend project. We tore the car apart a replaced the valve cover gasket. In the process we accidentally knicked a hose and created kind of a flap cut in it (very small less than 1/4") - but when we looked at it, it didn't appear to go completely through the hose, it just appeared to be on the surface. We set the hose aside along with the others and eventually lost track of which one it was, so when we put the car back together, the hose went back in without us fixing it. When we had the car apart, we realized it wasn't even a valve cover leak, but instead a transmission fluid leak. We solely went on what the mechanic told us - big mistake. My wife drives the car and it seemed to run fine after the valve cover replacement with the exception that the check engine light would come on and off. The only thing I could think of was the hose that we cut.One morning my wife was driving to work and when she was making a left turn at an intersection the car shut off. She turned it back on with no problem and it ran fine.I took the car to another mechanic recommended by my brother to look at the transmission. That mechanic said that it was the turbine control sensor in the transmission. He also said the the computer was giving a reading for the EGR Valve (I have the code) – he said a cleaning should do just fine.(I have not cleaned it yet) I was skeptical and took it to my old mechanic (we moved and don’t live real close to him anymore). He looked at the leak and said it was coming out of the breather tube / vent tube at the top of the transmission. He referred us to a transmission place who in turn told recommended we have the transmission rebuilt. We did so for $1800.After we got the car back, my wife immediately noticed a rumbling feeling every time she went 70 mph. We noticed that the RPM’s were at 2500 when it happened. It got worse and starting doing it around 40-45 mph, so I took it back to the transmission place. They didn’t really believe me so I insisted they test drive. As we got on the highway the car lost 4th gear. They kept the car two days and replaced a solenoid.Now, the car keeps rumbling. It is most noticed at 70mph/2200 RPM and at 50mph going up hills. I called the transmission guy and he is saying it is a brake problem. I replaced the brakes and rotors all around and have had them checked – no problems. My wife was driving the car this week while it was raining and every time she made a turn the car almost shut off. She pulled into a gas station and it was bucking like it wasn’t getting gas. She decided to drive it more to see if it went away and it did. She thinks the last time the car shut off in the intersection that it was also raining that day.I am not sure how many issues I have going on here or if they are all related. The transmission still rumbles, the engine light still comes on and off, and now the car shuts off or putts/bucks at times. Does anyone have a clue as to what some of these problems might be? Any help/insight would be greatly appreciated.
