Serious help, gas leak, white smoke.
JDMDude91
Car: 1993 Nissan 240sx
Drove the car yesterday morning to jury duty and noticed that there's been some lag when I shifted. Arrived, parked the car and I was there until I finished up around 7 in the evening. After all that time I could finally go home, or so I thought. Engine was bogging hard and I smelt gas. I figured I'd drive it a bit to see if the smell went away but no, saw white smoke coming out of the exhaust, so I pulled into a gas station. After parking it I noticed something leaking on the ground, put my hand on it and took a sniffed it, gas. Problems keep arising and I might have to sell this car :frown:
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Start checking fuel lines, fpr, fuel filter and I would pull the fuel rail and check your spray pattern and check for leaks there too. Check fuel pressure too.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
sounds like a stuck open injector or a bad injector o ring.
JDMDude91
Just bought a set of o rings, gonna replace them in the morning.
moso
90 240sx ka24de RIP
might i suggest using assembly lube to put the injectors back in with. makes it super easy.
sabretooth91
Car: 1989 240SX coupe
I've heard from someone else who had white smoke because his radiator hose was screwed up somehow and the water/antifreeze was mixing with gas.
JDMDude91
The problem so far was bad o rings, replaced 3 of them but the 4th injector seems to be stuck.
moso wrote:might i suggest using assembly lube to put the injectors back in with. makes it super easy.
Thank you for this, it helped a lot.
