The last time I got the car dynoed, I had the JWT flywheel, not the RPS, my A/F looked bad (in my unexperience opinion). I remember ratios from 11:1 down to 16 or 17:1 and the torque curve was anything but smooth.tollboothwilley wrote:What is abnormal to me is your All highway driving.
My guess is that with your mods are you running "fat"...didn't you get your car dyno'd before? Did they do an A/F at the time? Was that with the same mods?
The ECU could be compensating for the added air in by dumping more fuel but without an exhaust it might be reducing the power and gas mileage.
This makes no sense, BUT it may be the cause. I've always had the poor fuel economy since I got the car and it's always had an aftermarket flywheel. Maybe it has something to do with rotational inertia. Get a massive object in motion and it stays that way better than a less massive object?joe603 wrote:I noticed a big drop in fuel economy when I installed my CC lightweight flywheel/clutch combo. I was getting 20-21 city...now I get 17-19.
It may make some sense although to me it would be hard to quantify to the point of stating that it makes 'x' amount of difference.Sentientbydesign wrote:
Yeah, I spoke to him about that. Got to wait for him to get back from India and I'll get the place's details.tollboothwilley wrote:Nate.
I think you need a tune. But, you would want to get exhaust before then to take full advantage. If your AF went from 11s to 16s that would explain a very sloppy torque curve as well as bad gas mileage. 16s are very very lean. 11s are very fat. In addition to running better you would find GOBS of power if you are really running that fat/lean.
There is a place there in OC (talk to Vivek) where he gots his Osiris & dyno time for $500.
Wouldn't this make you cry? J/Ktollboothwilley wrote:I bet you'd pick up a good 25-30 RWHP with a proper tune and a good exhaust.
I'm soooo curious what I/E and a tune would yield to the wheels. $2k isn't really an option to blow on my car right now unfortunately. Anybody want a kidney?
I see similar results.smockers83 wrote:I haven't really read the OP, but I figured out that you're getting poor highway mileage. If I cruise at 80, I'll get anywhere from 26-28 MPG. A more in depth post is for later.
My last fill-up averaged under 17MPG for the 300+ miles.leeG35 wrote:I have a 06 Coupe with automatic and 40,000 miles on the clock. Fuel economy data to date gives me an overall average MPG of 22.3, with a low of 16.1 and high of 26.9. I consistently achieved 26 MPG during a 1,600 mile road trip cruising at a steady 70 mph.
I'm also still consuming oil and 4drmadness has my ghetto catch can. I'm curious how much oil is going through the PCV valve during a 3500 mile interval.
Yes.tollboothwilley wrote:How much oil are you consuming? Enough to do the OC test for the REVUP?
Warranty is over.tollboothwilley wrote:Are you still under warranty?
