Dorifto!RPS13 »
https://forums.nicoclub.com/dorifto-rps13-u42713.html
Wed Jun 28, 2006 11:12 am
I have a 1993 Nissan 240SX SE Hatchback (5-Speed Manual)
Ok I've gotten a whole bunch of people to tell me that I need a new something or other, I've heard I need a new Voltage Regulator, someone said I need a new Alternator, a new Fusebox, Relays, Battery etc. etc.
The symptoms are:
+Alternator is definately shot, I have to charge my car with one of those wall charger thingies every 2 days, the battery lasts about a day and a half or so until it runs out from just sitting in my driveway.
+"Meter" fuse blows whenever you put a 10-A fuse anywhere within like 2mm of it, huge spark and the fuse is shot (Have gone through 20+ 10's but don't want to risk using a higher fuse).
+A/C does not function, or the regular blowers. Automatic seatbelts do not function, gauge pod does not function, Cruise control does not function. The taillights, turn signals, headlights and the electric motor that raises the headlights function perfectly.
+Car takes a long time to start the first time after charging the battery (not sure if this is normal).
Wierd things that may or may not be related:
+The previous owner was pretty lame. He had all these make-shift solutions to problems, there was a random wire not connected to anything else on one of the fuses, my friend said this was a ghetto solution to allow more voltage through a fuse?
+Also did Sleepy-eye mod, basic type where you cut the brown wire or something.
+Aftermarket alarm, we figured this to cause some problems as the wires to the motion sensor were frayed, certain electrical things would go out when i closed the door (heavy vibration?). The alarm may have possibly been the kind that just shuts down everything electrical when it detects a break-in. Disconnected the alarm a while ago, I recall it fixing some problems but everything I stated is still occuring.
Please help! I really don't want to spend like $100 for a Nissan guy to look at it and maybe not even find the problem.
Thanks in advance
