slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Tue Feb 17, 2004 10:37 am
Ok I don't know much about the SR's electrical system, but I'll take a stab at this anyways...First, has the car ever run(ie before SR drop) since you'v owned it?
First off, if you have 0Vdc on E23 and 0ohms to ground(scen1), then there is surely a short between the battery and the E23 junction. A short that close to the battery should result in something noticable. Either a)spark 'n arkin'(dead bat), b)a blown fuse/circuit breaker, or c)heat/fire. I'm surprised you havn't drained your battery. This may seem obvious, but have you actually tested your fuses with a test lamp or ohm meter?
OK so you say that E102 should have a ground on it. Somewhere in that line is a short then. Check all your fuses first so you aren't chasing this short 'into a foxhole'. What I would do is this:
-Disconnect E102/M12 connector-On ONE side of this connection should be the short. Continue to do this(aka divide an conquer) until you find the short.
So for instance, if E102 has 12V on both pins, then short is from there back(left, relative to the schematic). Remove the Acc2 relay, check E102 again. If 12V still on both, check the relay holder/associated wiring. From there it's a short(no pun intended) path to the fuse box. -OR-
If M12 has 12V on both pins, then the short is from there to the right.
Sorry for not being more specefic, but I'm not sure on a few things relative to automotive schematics (like do the relay boxes supply a ground, or 12v circuit path)
Since you'v probably mucked with the wiring, it's hard to tell where the short may be. Use the fuses, circuit breakers, and temperature of wires(possibly heating up) to your advantage to isolate the short.
Hope this helps and doesn't confuse things even more.
Keep us posted.-Jamie
