Touchdown038 wrote:Yes, if you have to pump the brakes, either you have a leak in your lines somewhere, or air in the lines. Try bleeding them all again, in the order LR, RR, LF, RF. If that doesn't fix it, check for leaks along the hard lines. Also check to make sure you have enough fluid inside your master cylinder.
