Series 2 RB25det Auto ECU and TCM help
RBvipVert
Delete!
Modified by RBvipVert at 1:01 PM 5/8/2008
RBvipVert
HELP!!!!!!
StricNyne
as far as a auto ECU goes, i would look into possibilites of running a manual and if u cant, i would contact venus-auto or erics parts both in cali, as far as a tcm idk wtf that is
RBvipVert
StricNyne wrote:as far as a auto ECU goes, i would look into possibilites of running a manual and if u cant, i would contact venus-auto or erics parts both in cali, as far as a tcm idk wtf that is
Thanks for the contact info.
Unfortunately I cannot use a manual ecu as the automatic version has alot more built in logic and controls that send signals to the TCM (transmission control module). I'm not so sure the TCM as critical as the ECU. I was thinking about trying the KA one if i cannot locate a rb one.
RBvipVert
Anyone else have any other contacts? I cant imagine that someone doesn't have this stuff sitting in the garage.
neonbomb
You two are the only auto RBers ive ever seen lol
StricNyne
i got a manual, u can try import inteligence, jhot imports, heavy throttle, zero lift auto labs, jrautoparts (thats where i got my original rb25)
neonbomb
but you HAD an auto s14
RBvipVert
StricNyne wrote:i got a manual, u can try import inteligence, jhot imports, heavy throttle, zero lift auto labs, jrautoparts (thats where i got my original rb25)
Thanks for the help again. I have emailed all of them. Hopefully someone wants my money enough to help.
StricNyne
i am surprised erics parts didnt have anything, they usually had odd things i needed, you could also try, alamo motorsports, they are a long shot but they do tons of standalone work so they might have something laying around
StricNyne
from SAU
http://www.skylinesaustralia.c....html
Carl H
use the 240sx auto trans control unit to keep wiring somewhat simple and just locate an auto r33 ecu.
RBvipVert
StricNyne wrote:from SAUhttp://www.skylinesaustralia.c....htmlhttp://www.skylinesaustralia.c....htmlhttp://www.skylinesaustralia.c....html
Yeah I have been lurking on there for a bit. Thats where I found out the importance of needing the auto ecu. I have a friend that works in Sidney that used to work with me here in Charlotte so I may post a wtb thread in the classifieds. I would rather source one state side because shipping to and from australia is expensive.
RBvipVert
Carl H wrote:use the 240sx auto trans control unit to keep wiring somewhat simple and just locate an auto r33 ecu.
Carl that what I'm going to try to do. I think we talked about this already. Someone on skylinesaustralia said that it wouldn't work due to traction control but looking at the r33 diagrams and s13 diagrams they appear to be exactly the same. I have most of the wiring figured out now.
Carl H
r33 did not have traction control...the r34 did.
RBvipVert
Carl H wrote:r33 did not have traction control...the r34 did.
Nice to know. I could not find anything on it.
RBvipVert
I do have series one parts to covert the motor back so I can easily use a series 1 ecu if someone has one of those.
