frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Sun Mar 29, 2015 3:38 pm
Welcome to NICO!
Congrats on the new car.
I don't know a heck of a lot about those engines, but any time you buy someone elses work, you're always in for some extra work.
However, I'll try to help you out systematically...
The FMIC, coils, and exhaust aren't going to be your issue, but some of those sensors may be. However, since you're not revving very far, I'd check timing first. After that, plugs, assuming you haven't replaced them. Which RB ECU do you have? It might not be correct for the engine.
You've got some research to do, but start checking out the timing. If you're still having trouble, I suggest taking a peek at one of our vendors in the marketplace- Wiring Specialties. They've got harnesses for most any Nissan engine/chassis and if you can't find the answer through some conventional means, you can eliminate wiring as a problem if you buy a new harness from them. If you go that route, make sure to mention NICO and you'll get a discount.
