i am rebuilding my redtop sr20det money is tight being a college student. my goal is around 300whp dailydrifter.I was wondering about running 86.5mm ser pistons (not forged) i know the compression will be higher. Im aiming for 9:0.1 compression. I am boring out .020 over due to cylinder wall damage. I have a few questions about the piston and oil squirter clearance, timing, and of course fuel. If i run this setup i will invest in a methanol injection to help prevent detnotation. Does anyone have experience with these pistons?
Parts i already have:
new sr20 crank with bearings
forged eagle h-beam rods
oem full gasket kit(i wont be using oem headgasket because of bore so headgasket and oem piston rings are forsale)
parts up next:
arp head studs
87mm or 86.5mm mls headgasket ( ill be running 86.5mm bore can i run 87mm hg?)
86.5mm ser pistons
Thanks!
