I had thought about saying you should keep them both under the hood for oil pluming ease, but idk how space would be, mine is bottom mount and I'd like to keep it that way. Using a MAP would definitely be easier, you are on a full standalone I presume? I'm still a bit confused on why you think the small turbo will see vacuum and try and spool up, use a MBC between the cold pipe and the wastgate, should run just like my car does now, once the big guy takes over it will read way more boost than it's set for and hold the wastegate open to try and bleed it off. No? This is my first turbo car, and I've only had it ~1yr, I could be wrong on how that part works.
My concern would still be trying to pull though the amount of air that you want without the small turbo acting as a restriction. You are are prolly right about the exhaust, a big enough wastegate, or using an external and the internal will divert enough air to keep the small one from over spooling.
What else uses a system like this we could bounce ideas off of? I know the VR4 and Stealth R/T guys are the same size. Don't stock mkIV Supra's use two diff sizes turbo's? How to they switch between them?
In all honestly, this is a cool idea I'd love to see/experience, but is it worth the trouble just to get response? I mean, it's more of a bragging right. You could hook up a small 35/50 shot of nitrous on a WOT and window switch to kick in at 2/2.5k and shut down at 4/4.5k once you are in full boost on the turbo. Or even just do a dry kit that sprays into the header right at the exhaust wheel, set up same way, WOT switch and a 2k-4k widow switch.
Just for the sake of posting, here is one of the first guys to do a rmt on a Z24. He started with a stock 2.8, boosted it, then engine swap to a 3400, followed by a bigger turbo. Has done two high 11's passes with stock internals on 215 d/r's. He does address how to run a oil system back there.
http://khturbo.net/rmtz24/RMTZ24.html
