sequential shifter
ITR_KILLR
this kicks ***!!Ikeya-formula sequential shifter!:ylsuper http://www.takakaira.com
I H8 UR DSM
only if you have a rhd car : )
SWIFT_DRIFT
you still have to use the clutch, its just a "sequential adapter" so all you're doing when you shift is go up or down with the shifter.
SpeedRacer1
Car: 1990 240SX, G35
Its ok but not 1500 dollars ok. Though I guess its what some of the Japanese tuners prefer i'll stick to the stick.
ITR_KILLR
It only works on RHD??, that sucks
SWIFT_DRIFT
you would seriously spend 1500 on that ITR? damn.....
ITR_KILLR
If I had wads of money to get rid of your damn right i would!!:ylsuper, actually, if i had wads of money, i would just buy a holinger sequential transmission:ylsuper
battle D
Car: drifting
yah doesnt a hollinger sequential transmission cost like 16,000 i think hks makes a 6 speed sequential transmission for the sr20det, and are you guys sure that it works only on rhd's and that u still have to use the clutch
battle D
Car: drifting
yah doesnt a hollinger sequential transmission cost like 16,000 i think hks makes a 6 speed sequential transmission for the sr20det, and are you guys sure that it works only on rhd's and that u still have to use the clutch what about that twin mode clutch system from 5zigen
SWIFT_DRIFT
yes you still have to use the clutch for that ikeya shifter. the ikeya shifter is a mechanical device that mounts over your stick and all it is doing is making the H motions into forward and backward motions making it "sequential." It's not a true sequential transmission, just a little device...and it still costs 1500 omg.
ITR_KILLR
The 5Zigen twin mode clutch is close to 2G's I think, but i know it eliminates the clutch when activated. Can it be used on LHD?http://WWW.takakaira.com
I H8 UR DSM
you can make anything work on lhd....it just set up to be used on a rhd car, so you'll have to go from there...ya know
I H8 UR DSM
i believe the 'twin mode' thing, doesnt necessarily 'eliminiate' the clutch, but it just activates the clutch hydrolically with the press of a button or whatever, so the clutch is used, just not pressed with your foot...
ITR_KILLR
correct
