sequential gear boxes
Nissan dominates the drift scene - Always has, always will.
tux
hi witch gearbox is best a sequential or a manual?
Joe
it depends on how much money you have
a sequential will cost A LOOOOTTTTT of money, but its a ton better than a standard manual trans.
takklz
Car: 1993 BMW 318i
why are you buying one?
raging panda
Car: s13 coupe
Okay, disreguarding the fact that a sequential transmission is usually pretty trick and overbuilt stuff made so that it generally is harder to break than oem stuff, its not that much better than a normal manual transmission. The only real advantage is the fact that its harder to mis shift since all you do is push up or pull down, instead of having to pull to the left and up or something. If a normal manual had custom gearing, harder gears and all that other cool stuff, it wouldn't really matter, it would come down to personal preference. A sequential is really useful in a track car where the tenth of a second shifting may make a difference in lap time, not as important in drifting.
tux
no its just i can learn to drive in 6 months time and i am going to build a drift car over the next year or so and would like to know what sort of gearbox i should use
sil beer s13
Car: Kumori SPL S14
12k+
for a sequential
over your league.
bet you dont even have a lic.
jude240
Car: 97 240sx/99 Transam
What about a sequential shifter. Correct me if i'm wrong, I remember seeing a website a while back that sells those. I think it was around 1,200. I'll post it when i see it again
raging panda
Car: s13 coupe
ikeya formula sells one, but still, why? Many many many other things i could spend 1200 on, i think this one comes up as one of the last on my list.
GhostDriver
Car: 1991 Nissan 240SX RMS13
Damn...a sequential gear box? That seems like overkill. Do the D1 guys even use those?
Fenvy
Car: 2005 350Z Base 6MT
I wouldn't wnat it installed in my car even if it was free
it's almost like bmw smg... you take the fun out of driving a stick. I want to grind my gears, break my syncos and all that good stuff
Dookie
Car: 1993 240sx Coupe
GhostDriver wrote:Damn...a sequential gear box? That seems like overkill. Do the D1 guys even use those?
Taniguchi has one in the HKS S15 Silvia, although its not gonna be used anymore for D1 i hear
raging panda
Car: s13 coupe
yes, the HKS silvia did, Kumakubo uses one in his old S15 also, dont know if hes going to use it in the impreza.
tux
well after hearing that it is staying stock thanks for your advice guys
Return to “Nissan Drift Forum”
