Looking for a niles sequential flasher unit no.701090 out of my '71 Datto 1800 SSS 2 door to borrow to test the indicator wiring circuit. This unit is located in the boot and seems to work ok but can't be sure.
Got knocked back on a blue slip because the front indicators were too dull and slow.
I've stripped the dash out and only found one canister for the hazards. Not sure if I have the correct wiring
diagram as it shows another canister for indicators which I can't find. I need some info from you guys if you've had the same issue. Thanks in advanced John 0421 278 303
