shreqboi909 wrote:i had 215/45/17 in the front and 235/40/17 in the back on my V and it never rub. the fenders dont need to be rolled, if u check your fender, unlike other cars the V doesnt have the lip that usually gets rolled.
and it would be nice to have the Spec V wheels on the V. i rather go with those rims than with aftermarket 17's. since u can most likely find them cheaper and they will most likely be lighter than aftermarket. just my opinion =)
Well, to keep the speedometer accurate, 205/40R17 is what you need. Since that size means that the sidewall is 40% of 205mm (82mm) and you run 45% of 215 (96mm), the speedo will be off 5MPH or so LESS than your actual speed.
Not that I'm trashing your ride, I promise this, but what's the point of putting offset wheels on a FWD car? The reason you put wider tires in the rear is to have better traction on a RWD car, the contact patch is wider. On a FWD car, it seems almost pointless.
