I was actually thinking about going with those, but I'd rather go with the Sportmax 962s.locoluna825 wrote:yea i like what i see there
1. Save the picture2. Get a Photobucket account (if you don't already have one)3. Upload photo4. Copy IMG code5. Paste herelocoluna825 wrote:dam it how do i post a pic off google its not working >>:O
They will not clear Z brakes, front or rear. I have 26mm Z32 brakes front and rear and had to ditch my spec V wheels. you only need about an 8mm spacer in the rear, but up front was 30+mm.CaEric wrote:will they clear z brakes and if so with what size spacer's r needed
yes, they fit the stock setup without any spacers. however i had 225/45/17's and they were very close to the front struts, they might not fit with coilovers. i swapped my Z32 setup in at the same time i did my coilovers so i couldn't test it.truckmtr240 wrote:Will they fit without spacers?
Brembos were not an option until '04, hence the new wheel design to clear them.240_SeX wrote:02-06 sentras are all available with the same brembo package if i"m not mistaken
